Error Code--Aficio3224c-------->errer sc571
  • SAMER
    • Jul 2025
    hi
    i have error code with my printer
    code
    SC 571
    PLEASE TELL ME HOW I CAN TO FIX IT
  • vargue
    • Oct 2011
    • 404
    Re: Error Code--Aficio3224c-------->errer sc571
    check out psu and swap another power supply.....
    • SAMER
      Check it out the same defect
      • femaster
        • May 2011
        • 1504
        Not sure where PSU comes into play here, but here is the Service Code info:
        Click image...
        • Eric1968
          • 2458
          This is an SC about the Oil Supply Unit. The Oil Supply Unit is not detected by the machine. Could also be a defective Oil Overflow Sensor. Check the oil flow from the tank to the Supply Unit.
          Replacing the PSU will not solve the issue.
          • SAMER
            what the PSU mean can you help me with pic please
            • jettamand
              • Sep 2010
              • 30
              Originally posted by SAMER
              hi
              code
              SC 571
              Add fuser oil and do the "forced oil suply" or "add fuser oil" in sp mode...then it works !!
