2022 pcu lines
  • leo34staffs
    copierman
    • Aug 2007
    • 503
    2022 pcu lines
    Hi guys, What drums do you use on these machines, i tend to disablethe pcu check in sp mode and use the 1022 pcu. The trouble i am having is some of these tend to give charge roll lines quite early.
    Have any of you techs had this problem or do you replace the drum separatly rather than fitting the 1022 pcu?
    Networking skills are advantageous but use of a 3m vacuum cleaner is essential
  • hosennet
    • Mar 2007
    • 145
    Organic Photo
    Conductor Drum
    B0399510
    Edp Code 889662
    • Cipher
      It's not easy being green
      • May 2006
      • 1309
      We replace the complete PCU.
      Most of them reach there 60k yield for us.
      We even let them run over yield if the customer is not reporting a copy quality issue when they phone.
      • leo34staffs
        copierman
        • Aug 2007
        • 503
        do you use the 1022 pcu?
        • Cipher
          • May 2006
          • 1309
          DMU23 which fits various older models, I think the 1022 is one of them marked on the box.
          • rthonpm
            • Aug 2007
            • 2859
            Do you also replace the transfer roller as well? I've seen quite a few of them that will end up damaging the drum or give lines that look like charge lines as they wear.
            • Cipher
              • May 2006
              • 1309
              The transfer roller is down as a 120k PM part but we don't replace them unless we see they are damaged.
              Some of our 1022/27s are well over a million copies on their original transfer roller.
              • paulg
                • Jun 2007
                • 278
                The same material charge rollers is used in 2238cs and 3245cs itbs which last a million and all we do is wipe them with water which does the trick in most cases unless damaged.
