Ricoh Mp201Spf Scanner Windows 7 not connecting
  • treloyarakias
    Mad Man
    • Dec 2007
    • 31
    Hello everyone.I am trying to install the scanner of mp201spf to windows 7 and it keeps telling me that i can not establish connection.I even tried from the pc to connect and nothing happened.Any suggestions please????
    The Essentials Of Imaging
  • sandmanmac
    • 3963
    Re: Ricoh Mp201Spf Scanner Windows 7 not connecting
    Do you have experience with connecting it for scanning? Have you made all of the necessary settings? Was it previously connected? Does it work in an XP environment. If so, I would suggest it's a firmware issue to allow scanning in Win 7
    • copyaction
      • Oct 2007
      • 985
      Norton or firewall blocking it?
      • chowles
        How are you connecting. is it with a crossover cable or on a router. is the macine runnung on DHCP or a static address.
        I have found that sometimes I have to create a seperate user account for the scanning to work. Share the folder with read write permissions in advanced sharing and in security. then allow the port through the firewall on either windows firewall or whatever firewall the customes is using. Port 3670.
        • treloyarakias
          Mad Man
          • Dec 2007
          • 31
          Yes!It works on Xp but not on windows 7.It is very strange thing.I made all the necessary moves.Also it is not connecting from the web interface nor the machine??HHHHEEEEEELLLPPP
          • tonnerboy
            • May 2011
            • 212
            You can not open the WebImageMonitor (web interface). Did you try to ping the IP machine? Did you try to conect directly to the machine (Laptop-to-MFP)?
            • sandmanmac
              • 3963
              Firmware
              • knightfall
                • Jul 2006
                • 633
                these copiers already come with the firmware that supports windows 7, you said that win xp can scan to it but not win 7 than its something in win 7. Is file and print sharing enabled? There is already alot on this topic you may want to search this topic here.
                Get your facts first, and then you can distort them as much as you please.
                • sandmanmac
                  • 3963
                  cool..that's good to know for future too.
                  Some settings to check, and that seem to help on WIN7 are:
                  For "authentication", use the actual administrator account name vs. using "administrator" (if applicable)
                  For "path", Try using PC name rather than the IP address and vice versa
                  As others have said, turn off any firewall, and check operation
                  Turn "ON" file and printer sharing make sure password protected sharing is "Off"
                  Make sure full privileges are allowed in the shared folder.
                  After saying all that, I've encountered a situation a couple of times with 5 or 6 Win 7 pc's in an office, all identical in every way, purchased and installed on the same day, and connected all but 1, and never able to get that last one working (I hope this isn't the case), but if so, maybe install a 3rd party FTP server and set it up that way
                  • treloyarakias
                    Mad Man
                    • Dec 2007
                    • 31
                    problem solved!!!Thank you all.
                    • patterson70
                      • May 2010
                      • 580
                      Do you know what solved it?
