Scan file from Ricoh 470W Scantool 3.7.1 sp4
  • bill_cheah
    • May 2008
    • 9
    Can someone analyze what's wrong with this scan from a recently install Plotbase 3.7.1 sp4. The scan image distorted by vertical white lines which is consistent in distance. Thanks.
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    Re: Scan file from Ricoh 470W Scantool 3.7.1 sp4
    I rarely work on wide format but my best guess would be.
    Problem: White lines every 1mm pitch in halftone areas.
    Possible cause: Defective CIS (Contact Image Sensor E.G the optics ass'y)
    • bill_cheah
      • May 2008
      • 9
      The problem is that I have no problem at all doing copying. Copy quality is perfect.
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        Try reseating both ends of the interface cable between the printer and the interface card, making sure that there are no bent pins, dirty contacts, etc...
        When you reconnect, make sure that you don't reverse the ends, even though they would fit.
        If that doesn't work, crack the PC open and reseat the interface card in its PCI slot.
        These cables and interfaces can be funky, to say the least.
