MP 7500 Power Saver and Operation switch are not responding
  • trilesmana
    • Aug 2025
    Hi, Juts bought refurbished Ricoh Mp 7500 copier, and I've just realized if the Power saver and Operation switch are not responding.If I push those button, two long beeps will heard but no response from the machine (the machine still ON). From Op manual/guide the procedure to turn off the machine (in sequence) is by turn off the operation switch first and then turn off the main power switch. Since the operation switch is not working, I just turn the main switch to off position. My questions are: 1. Will it harm the machine, if I turn off the main power switch directly? 2. Is there any setting that causing this condition? (power saver and operational switch not responding/not active?) Thanks for your help. BR, Tri
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: MP 7500 Power Saver and Operation switch are not responding
    You should be fine just dropping it by the main switch. The machine outrightly refusing to shut itself down could becaused by several things, twitch hard disk, locked open fax line, couple of others. See what it does when you reboot it and post back please!
    Hit it.
    • Jomama46
      • 2900
      You might just pull that conpane and see if the harness for that section is connected.If its ok then in User Tools, hold down the # key and press the System setting button to reset to default.
      sigpic
      A+; Network +; PDI+
      • trilesmana
        Hi TonerMunkeh,
        Thanks for your response. So, is it save to turn off the machine through the MAIN SWITCH eventhough I do that everyday?
        I have tried to reboot the machine twice, but the "problem" still there. And I found two different machine condition:
        • First attempt: After rebooting the machine, everything looks normal. Tried to push the operation button (nothing happen, with two long beeps heard), push the power saver also has the same result. After that I push the USER/SYSTEM SETTING to find out the current setting, but Suddenly the display was turn off and 5 seconds later the display ON again displaying PLEASE WAIT.... I wait for about 3 - 4 minutes, the machine still on that condition. I reboot the machine for the 2nd time
        • Second attempt: The machine is UP after rebooting, check everything looks normal except FAX SETTING (on user setting) was missing. Exit from user setting, push the FAX front panel button and the front panel display show "LOADING" text. Wait for about 3 minutes, the LOADING text still there, hence I choose to exit from FAX and go to COPIER menu. I repeat as per step one to push the operation button and power saver button, the result still the same, two long beeps sound heard but the machine was not respond.
        That's all activity that I have done, your advice is highly appreciated.
        BR,
        Tri
        • trilesmana
          Thanks for your response, but could you please explain more detail about it? what is conpane section?
          BR,
          Tri
          • Jomama46
            • 2900
            Conpane= control panel
            sigpic
            A+; Network +; PDI+
            • ucinn
              • Jun 2009
              • 383
              Sounds to me that you have a bad fax module. Has the fax ever booted up completely? That would explain it not shutting down with the op panel power switch or the energy saver button not working too. If you do use the main power to shut down, make sure it isn't active.. like pocessing a print job or anything because you could kill the hard drive if it is using it while shutting down.
              • trilesmana
                The fax module is boot up completely on the first day this machine arrive on my place, and I got this problem on 2nd day. I can check the machine activity (active job processing) through the JOB LIST menu, but - how can I check the certain module is active or not? (loading, checking etc etc...).
                In case the module is broken/bad, can I just disable it from the setting menu or should it be remove from the machine?
                Thanks,
                Tri
                • trilesmana
                  I see ...thanks. Got to check it immediately.
                  • mrwho
                    Major Asshole!
                    • 4299
                    I'd also check the logging data for any hidden sc codes.
                    Mascan42
                    Ibid
                    • techsass
                      • Dec 2010
                      • 248
                      There's a piggy back PCB for the fax that tends to come loose and cause the fax "Loading" as well as the "Please Wait" scenarios. It probably came loose during the delivery of your machine.
                      • ucinn
                        • Jun 2009
                        • 383
                        Thanks,
                        Tri
                        When everything is booted up, hit the fax button, if it constantly says loading... then it's not booting up. If your main fax screen is there, then it has booted up fine.
                        • trilesmana
                          I called the seller, and their technician trying to solve the problem but failed. They just send me the replacement unit.
                          Any suggestion how to maintain this 2nd hand unit to prolong its lifetime? I have checked the operation setting, output copier, print out and scanner result everything were good...but I just want to make sure the component inside the machine also OK.
                          Tri
                          • JustManuals
                            • Jan 2006
                            • 9838
                            Paul@justmanuals.com
                            • trilesmana
                              Thanks Paul ...
                              Originally posted by manuals4you
                              This Parts & Service Manual can now be purchased for $12.77 and downloaded immediately after payment from Just Manuals ~ The Internet's largest selection of manuals ~ Instant Downloads Paul@justmanuals.com
