We had a major power outage in my area and I have 3 machines down all odf them are MPC 3500s . In copy mode it wont come ready and when I enter service mode it doesnt display the fax and scanner icons . What the hell is blown on these units help please.
MPC 3500 had a power outage and wont come to ready
Re: MPC 3500 had a power outage and wont come to ready
Not sure how much help this is going to be, but here it is.Attached FilesNEVER ASSUME ANYTHING -
A power outage generally won't kill a HDD, but might cause data to get spewed across the drive, scrambling things up.
If you can't get the HDD to format in the machine, pull it, connect it to a PC with a USB adapter device like this (LINK). Initialize and do a quick format of the HDD using your PC, then put it back into the copier.
The idea of formatting it via the PC is to wipe out the copiers data structure, which will then allow the copier to format the drive back to it's own structure. This works great in a machine that refuses to boot up after such an incident. It won't help if the HDD is truly dying, or dead, but is a cheap way to get a scrambled drive back in action fast...A Ricoh Service Tech for 7 year. A Konica Minolta Service Tech for 7 years. Now, KM service manager for 4 years.
My Ricoh knowledge is slowly dwindling away at this point. Many things have been lost to time...Comment
The idea of formatting it via the PC is to wipe out the copiers data structure, which will then allow the copier to format the drive back to it's own structure. This works great in a machine that refuses to boot up after such an incident. It won't help if the HDD is truly dying, or dead, but is a cheap way to get a scrambled drive back in action fast...Comment
