Ricoh 2238c - send to folder issue
  • aramalla
    • Aug 2025
    hi guys
    does this scan to folder works okay with Ricoh 2238c?
    I setup every thing as per the manual, but still it does not work.
    Previously this was set up sent to email, but it is not working due to SSL thing.
    now, we want to setup this scan to folder option, so that users can retrieve the scanned documents from the shared folder, but it is not working driving me crazy.... any ideas..
    thanks in advance
    regards
    aramalla
  • aramalla
    Re: Ricoh 2238c - scan to folder issue
    if the email configured, the scan folder does not work? not sure, never did this before.
    • aramalla
      Re: Ricoh 2238c - send to folder issue
      any one, please help....
      • rthonpm
        • Aug 2007
        • 2859
        This model requires custom firmware to scan to folder in a server 2003 environment. They will not scan to folder in a server 2008/Windows 7 environment because of the higher encryption NTLMv2 requires. It will work in a workgroup environment though.
        • sandmanmac
          • 3990
          If the internal email account requires SSL, then you could setup an email account through "Yahoo" to use as your default 'send from' account, as it doesn't require SSL, put in the necessary info SMTP (use the ip address not smtp name here), username, password, etc. This is a workaround I've used several times
          • aramalla
            ours is 2003 server environment.. where can I get this custom firmware?
            • aramalla
              ohh, this will be even better, email ..
              yes, our email account requires SSL
              can I use mail.yahoo.com IP address instead the SMTP name?
              will try now and let you know..
              • copiman
                • Sep 2011
                • 861
                Take a look at Ricoh.com. Under support there is a knowledge base area that has step by step on setting up all types of scanning, with pictures, that will help you.
                • aramalla
                  no luck, tried as below..
                  SMTP Server Name: 217.146.187.123
                  SMTP Port No.: 25 (may be this has to be changed)
                  SMTP Authentication: On
                  SMTP Authentication user name: xxxxx@yahoo.com
                  SMTP Authentication Encryption: Auto Select
                  any thing else I need to setup...
                  • aramalla
                    I download the manual, trying to setup exactly what it says, but still no luck with both email and scan to folder.
                    I can under with email problem, as ours is SSL, ricoh does not support SSL etc.
                    but scan to folder, I could not get an idea why it is not working !!!
                    • rthonpm
                      • Aug 2007
                      • 2859
                      Server 2003 custom firmware is available to any tech with a valid Ricoh ID. You may have to call one in. We poor independent guys don't have access!
                      • sandmanmac
                        • 3990
                        My apologies. A quick search suggests that 'Yahoo.com' requires SSL, whereas 'Yahoo.ca' here in Canada does not.
                        Another workaround that ALWAYS works but requires the pc in which it is installed to be ON, is installing "Stunnel" which work in conjunction with a GMAIL account.
                        You can download it here:
                        stunnel: Downloads
                        The configuration to make it work with the SSL on your Gmail is here:
                        Stunnel Setup.pdf[ATTACH]14102
                        Good Luck
                        • SCSI
                          • 19
                          I dont remember how to set up scan to folder on this machine
                          If you need to scan you can download scan router lite and use that to set up to scan to folder, make sure you put in the firewall to allow port 3760.. or 3670 i dont remember which one it is.
                          this program only works with xp. It has a problem sometimes with vista and will not work with 7. only install it on one computer.
                          • copiman
                            • Sep 2011
                            • 861
                            hi guys
                            thanks in advance
                            regards
                            aramalla
                            Maybe this will helpScan to Folder White Paper.pdf
                            • aramalla
                              the very same white paper I am following, for some reason it is not working...
                              Maybe this will help[ATTACH]14103[/ATTACH]
