mp 6500 intermittent sc541
  • kopikat
    • Jan 2011
    • 15
    Hi all,
    I know if you have a few of this model you have come across this error.
    Word from ricoh is replace thermistors, upgrade firmware, try the new brackets,
    Anyone
    (same as old, well make no difference) oh yeh i almost forgot increase cleaning web on timing
    to keep the ufr "cleaner". got an answer cheers.
    Eamo.
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: mp 6500 intermittent sc541
    That is basically the answer. Update the thermistors to part numbers AW10 0131 and 0132 and fit the modified brackets and thermostats. That should sort you out.
    Hit it.
    • kopikat
      • Jan 2011
      • 15
      Yeh done all that still. Comes in from time to time
      Have about 50 of this model in the field
      Never happens on some of them weird !!
      Thanks for your reply.
      • xordi69
        • Jun 2010
        • 200
        put all timer settings to 60 minutes
        • rthonpm
          • Aug 2007
          • 2852
          Poor voltage/amperage can also cause this. I had a few of these that weren't getting enough amps from the wall thanks to a few too many devices running from the same circuit.
          Check your power...
          • lydell1087
            • Feb 2012
            • 3
            If are you using non OEM heat rollers this could cause a problem also.
            • Max
              • Oct 2011
              • 555
              paper in the power connector of fusing unit? or possibly power connector arcking out?
              • NeoMatrix
                Senior Tech.
                • 3513
                Make sure that you have not accidentially swapped the Blue, Green or White plugs on the rear end of fuser unit. (easy to do after a rebuild)
                If you do make this wiring mistake the fuser unit will turn on the wrong heater lamp at the wrong time and the thermistor heater timing will be in error.
                There is also a mod bulletin for the thermistor mounting frames for the MP7001 similar.
                • daveyt
                  • 15
                  We had the same problem, replaced the therms, and the mod bracket, even replaced the whole fuser. It usually happened on monday mornings, after machine had been in stand-by over the weekend. And usually in winter when it was cold. So we turned, "AOF"- off in user tools. This ment that it will never go into "power save". So no heat up failures. But then you have to set in SP mode,(I can't remember at the mo which ones) for the fuser to rotate at certain intervals, to prevent flat spots on the press roller.
