Ricoh MP3350 gray copy
  • Will
    • Jun 2007
    • 171
    Have MP3350 with washed out solids and half tones on copies. Already replaced drum, charge roller, developer and ran initialization. Seems to have
    setup ok but copies still gray on solids and halftones with pin holes in them. Which SP modes should be adjusted for correct solid density??
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Ricoh MP3350 gray copy
    I'd try replacing the transfer roller first, that can cause odd image quality faults on Russians.
    Hit it.
    • Will
      • Jun 2007
      • 171
      Can't you tweek one or two of the SP modes to boost the density level?
      • TonerMunkeh
        Professional Moron
        • 3865
        No. Messing with SP modes only masks a fault for a short time.
        Hit it.
        • jonezy999
          just one copy??
          • Feb 2010
          • 952
          How do internal prints look? Are the optics clean? Laser dust glass?
          I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
          • Counsel
            • Aug 2011
            • 529
            Make sure the laser slit glass is clean, I have also had grey prints/copies caused by a dirty mag roller even though it doesnt look real bad just taking a good brass brush or crumple up a piece of paper if you dont have a brush and scratch the dev build up off the mag roller, id try that cause its free and if they still look spotty then i would go for the transfer roller like suggested before.
            • mackattk
              • Jun 2011
              • 5
              Sounds like poor transfer roller contact or defective roller holder.
              • Oze
                Ricoh Fanboy
                • 1663
                Mack...do us a favour?
                Stop trawling the forums for old posts?
                Not meaning to be rude but these are old posts and either the OP fixed the issue or got hit by a bus before they could post that the mc is fixed
                The very first page of the forums has a list of all the newest posts.
                Oh....and welcome to the forums
