Hello! I was printing and a paper jammed coming out of the printer. I removed the jammed pages, closed the doors and then received an error code SC290. Any info as to what the code means and how to fix it would be greatly appreciated!
Ricoh Alficio SP C811DN error code SC290?
4info
Re: Ricoh Alficio SP C811DN error code SC290?
2XX Laser exposure
200 - Polygon motor
220 - Synchronization control
230 - FGATE signal related
240 - LD control
280 - Unique for a specific model
290 - Shutter
It looks like there is an error with the Laser Shutter Unit. You may have dislodged something when you have removed the paper jam. I would have a look in the area where you removed the paper and look for anything that might be bent or broken.
I assume you have tried the simple things like totally powering off and on?
Hope this helps. -
A general Richo error code list is here:
Printer Diary: Ricoh Error CodesComment
the shutter tends to slide somewhat heavy, so the shutter motor has not enough power to move it correctly in position, take out the laser unit and remove the shutter, but leave the actuators in place and you should be doneIf sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!Comment
Paul@justmanuals.comComment
mrtoner
I would like to get the list of error codes - please help
thanksComment
Use the "ricoh error codes" link at the bottom of his post, or try another browser. Worked fine for me 2 seconds agoComment
mrtoner
No.
Type Details (Symptom, Possible Cause, Troubleshooting Procedures) Shutter sensor time over error: Close The shutter close sensor does not detect "ON" for 2000 msec after the shutter motor turns on. 290
D - Defective shutter close sensor
- Disconnected or broken harness
- Defective shutter motor
- Defective shutter
- Shutter motor overload
- Defective IOB
- Check or replace the harness.
- Replace the shutter on the laser optics housing unit.
- Replace the shutter motor.
- Replace the shutter close sensor.
- Replace the IOB.
mrtoner
Some error codes are similar across the Ricoh range, but not all. What error code(s) are you looking for? And for what model? If you want this one, it's:
No.
- Defective shutter
- Defective IOB
- Replace the IOB.
681-133
861-123
861-143
Ricoh SP C811DNComment
