Ricoh Alficio SP C811DN error code SC290?
  • 4info
    Hello! I was printing and a paper jammed coming out of the printer. I removed the jammed pages, closed the doors and then received an error code SC290. Any info as to what the code means and how to fix it would be greatly appreciated!
  • Iommanxman
    • Aug 2009
    • 180
    Re: Ricoh Alficio SP C811DN error code SC290?
    2XX Laser exposure
    200 - Polygon motor
    220 - Synchronization control
    230 - FGATE signal related
    240 - LD control
    280 - Unique for a specific model
    290 - Shutter
    It looks like there is an error with the Laser Shutter Unit. You may have dislodged something when you have removed the paper jam. I would have a look in the area where you removed the paper and look for anything that might be bent or broken.
    I assume you have tried the simple things like totally powering off and on?
    Hope this helps.
    • jummamaster
      • Mar 2009
      • 99
      A general Richo error code list is here:
      Printer Diary: Ricoh Error Codes
      Ricoh Error Codes
      Canon Error 5100
      Canon Error B200
      j
      c
      • Herrmann
        • Jan 2006
        • 792
        the shutter tends to slide somewhat heavy, so the shutter motor has not enough power to move it correctly in position, take out the laser unit and remove the shutter, but leave the actuators in place and you should be done
        If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
        • JustManuals
          • Jan 2006
          • 9838
          Paul@justmanuals.com
          • mrtoner
            Hi - the link for Printer Diary: Ricoh Error Codes is dead, and when I click on Ricoh Error Codes, the page comes up briefly, then blanks out while 'blogspot.com' keeps running.
            I would like to get the list of error codes - please help
            thanks
            • sandmanmac
              • 3980
              thanks
              Use the "ricoh error codes" link at the bottom of his post, or try another browser. Worked fine for me 2 seconds ago
              • mrtoner
                Thanks! worked fine
                • ruben
                  The New Guy
                  • Oct 2012
                  • 1203
                  thanks
                  Some error codes are similar across the Ricoh range, but not all. What error code(s) are you looking for? And for what model? If you want this one, it's:
                  No.
                  Type Details (Symptom, Possible Cause, Troubleshooting Procedures)
                  Shutter sensor time over error: Close
                  The shutter close sensor does not detect "ON" for 2000 msec after the shutter motor turns on.
                  290
                  D
                  • Defective shutter close sensor
                  • Disconnected or broken harness
                  • Defective shutter motor
                  • Defective shutter
                  • Shutter motor overload
                  • Defective IOB
                  1. Check or replace the harness.
                  2. Replace the shutter on the laser optics housing unit.
                  3. Replace the shutter motor.
                  4. Replace the shutter close sensor.
                  5. Replace the IOB.
                  • mrtoner
                    No.
                    290
                    D
                    • Defective shutter
                    • Defective IOB
                    5. Replace the IOB.
                    I am looking for these error codes:
                    681-133
                    861-123
                    861-143
                    Ricoh SP C811DN
