Aficio 220 spews toner
  • landspeeder
    • Feb 2010
    • 355
    from the pcu unit after 40k and with any other pcu unit...pulled some out of other copiers it, still does it.
    any ideas?
    You never realize how cheap a professional is until after you let an amateur do it.... and
    if this was an easy thing to do then everybody would be doing it! But it isn't and they are not!!
  • sandmanmac
    • 3985
    Re: Aficio 220 spews toner
    It's not the PCU, but rather the foam "slider assembly" seal in the toner hopper assy. You've probably noticed that the tray of the hopper is filled with toner too, then as the bottle spins, the toner spills out onto the PCU, etc. Either replace the hopper assy, or the slider assy inside the mouth of the hopper (the the bottle seats up agianst).
    (Item #10 in diagram). This is an AF2022 diagram but the hoppers are universal.
    220_2022 toner hopper.pdf
    • landspeeder
      • Feb 2010
      • 355
      Thankyou for the info...now that my friend is a awesome response!!!!
      • sandmanmac
        • 3985
        Happy to help. I've replaced dozens of these in all kinds of Ricoh Models. They run clean as can be with the new slider
        • Gift
          • Mar 2011
          • 2459
          Yep - common issue plus sometimes the toner hopper housing itself isn't sealed properly, especially that little extension that passes the toner into the PCU. Another possible issue might be the mylars inside the hopper - these tend to "bend" (or sometimes fell off) so they can't properly move the toner towards the PCU. In this state the toner level inside the hopper rises what also leads to leaking issues. THe A220 is >10 years old so I'd probably go with a new hopper if it's not too expensive.
