Ricoh Aficio 551 Service Code:738
  • presstro
    • 7
    I have problem with Ricoh Aficio 551 service code: 738. Has checked and replaced all motors but still not ok.
    Can anyone help?
  • scully
    • Mar 2006
    • 46
    The Finisher Shift Tray Lift Motor is producing an error.
    Have you checked the Stack Height Sensor ?
    Also check the Tray itself as there are plastic lugs on the underside of the Tray which break off and cause this fault !
    John
    Uk
    • presstro
      • 7
      Ricoh SC738
      I think I have changed the Finisher Shift Tray Lift Motor(Is it the one on the top left hand corner? Do you have schematic diagram for the Stack Height Sensor? I might have checked that as well.
      John
      Uk
