mpc 3500 false add toner messare
  • acsolutions
    • Jun 2010
    • 519
    [Error Code] mpc 3500 false add toner messare
    Hello,
    I got a call for an add toner message, the customer added a cyan and black cartridge. They told me they added both bottles two weeks ago and it still saying add toner. I went into the service mode and checked toner remaining for each cartridge I believe it was 3101-9,10,11,12 for B,M,C,Y both magenta and yellow were in the plus side in grams and black and cyan were in the negative ( Black -43.25 grams and cyan -11.345) so the only thing I can think of is the bottle is not being recognized as being new. I could not find a way to reset the bottle as being new, I hunted it down for about 1/2 an hour. The copies are coming out great, so it is adding toner. Someone suggested initializing the dev. but I thought that was a bad idea. I'm not sure if there is an issue with the bottle chip on the black and cyan or what reads them is the problem. I did pull out the black and cyan toner and the machine tells me to insert toner cartridges. Thanks
  • Counsel
    • Aug 2011
    • 529
    Re: mpc 3500 false add toner messare
    Can't remember if you can do it on that machine but I think you can go into sp 3045 and turn off toner end detection, then exit service mode, make a few skyshots in full color mode, power off the machine completly and back on, then go into sp mode and turn then end detection back on. then run some testing for a bit make sure density is ok. I know this was one way to fix a toner end status on the 2800 and 3300, not sure if it will work if it doesnt then it could be a mechanical failure.
    by the way were the so called empty bottles really empty, just in case if they were half full or something and it gave an end message there is probably something else wrong. But I have had machines run then bottles dry and not want to come out of a toner add until its cycled a few times to get toner into the dev unit.
    • acsolutions
      • Jun 2010
      • 519
      I believe I did turn off the toner end detection and rebooted machine but did not run full color sky shots. The customer did say the bottles may have had toner in them when the message turned on. Logically it seems as though you should be able to reset that value and start with a new bottle of toner. the machine say's it's negative toner but it keeps on adding Thanks for the response
      • iMind
        Vacuum Cleaning Expert
        • Mar 2008
        • 1116
        Originally posted by acsolutions
        Hello,
        replace toner pump and tube as a hole.
        • acsolutions
          • Jun 2010
          • 519
          but its making great copies!
          • Jomama46
            • 2900
            Or as a whole, if that doesn't work.
            sigpic
            A+; Network +; PDI+
            • mikadonovan
              • May 2008
              • 2931
              This may sound stupid, but shake the heck out of the bottles and reinstall them. I've seen toner clump in the bottle and cause this problem. Also, the bottles installed weren't previously in another machine, were they? Once installed the bottle kind of marries itself to the machine making a swap not an option. I personally have only had one bottle out of many that had a bad chip in it.
              NEVER ASSUME ANYTHING
              • iMind
                • Mar 2008
                • 1116
                LOL... yep, sorry for that.
                • RICOHTEC
                  • 42
                  hi
                  to have a good value for the amount of toner in the cartridge make an ENGINE clear RAM and then change your developpers.
                  • Jomama46
                    • 2900
                    Originally posted by RICOHTEC
                    hi
                    Wow, that's kind of drastic.
                    sigpic
                    A+; Network +; PDI+
                    • mikadonovan
                      • May 2008
                      • 2931
                      X2
                      • iMind
                        • Mar 2008
                        • 1116
                        • TonerMunkeh
                          Professional Moron
                          • 3865
                          An engine clear can be the only cure for this on Athena's sometimes. Never had to do it on an Apollon tho.
                          Hit it.
                          • iMind
                            • Mar 2008
                            • 1116
                            Hummmm...
                            • acsolutions
                              • Jun 2010
                              • 519
                              developer assemblies or just the powder!
