MPC2500 and MPC2800 Tray1 ON jams
  • cbr600
    • Jun 2010
    • 71
    I have those 2 models wich are giving me some problems bouth on TRAY1 ON (jams).Actualy the paper is not feed from tray1 and give this jam.I replace the feed and separation roller but pointless, i checked all the sensors from the feed unit and all are working.I found something when i searched on forum but it was a b/w copier and the feed system looks different.Any advice ? THX
  • cbr600
    • Jun 2010
    • 71
    Re: MPC2500 and MPC2800 Tray1 ON jams
    I forget to mention the jam is random.
    • TonerMunkeh
      Professional Moron
      • 3865
      One reason for these jams is the white clip that holds the feed and seperation rollers in. Because it's only held in with one clip, it moves away during feeding and the feed tyre disconnects from it's drive. Take the feed station out of the machine and put a small self-tapping screw down the shaft the feed roller sits in and screw the white clip to the feed tyre shaft, obviously not too tight or it'll stop the feed roller turning.
      Hit it.
      • cbr600
        • Jun 2010
        • 71
        U talking about nr 13 and 15 from this image ?
        • Counsel
          • Aug 2011
          • 529
          Bridge unit switches, and firmware update. TSB 53
          • luke001
            • Dec 2011
            • 46
            Check SP mode - Jam location. If many jams At Power On - like wrote Counsel - Bridge unit switches.
            • TonerMunkeh
              Professional Moron
              • 3865
              Item 14. When you put it into the feed station, you'll see the hole to put the screw into the feed tyre shaft. It basically stops the feed assembly from moving side to side too much.
              Hit it.
              • cbr600
                • Jun 2010
                • 71
                luke001 and Counsel jams are at TRAY 1 on. I will try TonerMunkeh way
                • granata
                  • Jan 2012
                  • 34
                  hi, CBR600, the advice I give you in addition to former colleagues and one way to clean the back of the paper feed, I solved with a little oil on a cloth and then with a screwdriver to rotate the cloth dampened within one way
                  • granata
                    • Jan 2012
                    • 34
                    Part forgot to list entry 17
                    • Gift
                      • Mar 2011
                      • 2459
                      I've also had a few bad clutches in the MPC series but that white clip issue is also familiar. You can modify the feeding unit with a washer so the clip sits tigher. I've also heard about people removing the clip.
                      Bad bridge unit switches doesn't make specific jam counts but indeed a high count on "at power on"
                      • cbr600
                        • Jun 2010
                        • 71
                        I will inform u i used TonerMunkeh method will see if that works.thx.My model doesn't have bridge.
