MPC 2800 No Power
  • tcateach101
    • Aug 2025
    MPC 2800 No Power
    Hey,
    I have a MPC 2800 that is not booting up only the main power light comes on.
    Issue arrose after paper jams and then machine was power cycled. I have tryed a new PSU, BICU and I/O board.
    Where can i go from here???
  • TCA TECH
    • Mar 2009
    • 104
    Re: MPC 2800 No Power
    Hey,
    Unplug the power form the BICU and see if that turns on machine, if it does just go through all the connectors one at a time to see the line pulling down the voltage.
    Copiers are only as good as there last service
    • Oze
      Ricoh Fanboy
      • Jul 2008
      • 1663
      Try unplugging the HDD and powering up the machine.
      Customers have a nasty habit of flicking the power off if they can't clear a jam for some spastic reason and the HDD may have been in the middle of something at the time.
      • Polarbear
        • Feb 2012
        • 1070
        I would go with the HDD also, as most of the new generation colours won't boot it the hdd is dead or not connected. It is almost as if it is seeing the hdd as extra memory, and will not start without it.
        Press the GREEN button!!
        • TonerMunkeh
          Professional Moron
          • 3865
          Polygon mirror motor can also cause this. There's an updated one, part number AX060396.
          Hit it.
          • TCA TECH
            • Mar 2009
            • 104
            Pinched cable on the duplex pulled down the 5v line, problem fixed
