This is common to several models using the same type fuser. I came up with what appears to be (so far) a good fix without replacing the housing. Use a bearing with a groove and ring, and install it on the rear side only. Situate the ring against and on the outside of the metal piece ("side plate, rear"). The ring will not allow the heat roller to drift! You may have to cut a small part of the ring off, and put the space it leaves at the press roller bearing so the bearing doesn't contact the ring.
Fuser housing tab broken at HR bearing
