MPC5000 - Lines on copies
  • OutlawTorn
    • Aug 2008
    • 189
    Hey all, been at an MPC5000 today that is doing my head in. There are black lines across the top of the copies. Fair enough, I tested all the colours to isolate which drum unit was the faulty one, only problem - the lines appear with all colours! I then checked the ITB which appears to be fine and gave the ITB cleaning unit a good clean too. Fusing unit and transfer roller also seem fine.
    Did internal prints to make sure it wasnt the optics either!
    Can anyone suggest what this might be as all I can think of at the minute is ordering all the drum units and ITB cleaning unit!
    Cheers.
  • Eric1968
    • 2458
    Re: MPC5000 - Lines on copies
    Could be drums and/or ITB-Cleaning Unit. What are the meter readings for all PM-parts? Drum Units last for 120k and the ITB-Cleaning Unit lasts 240k.
    • Gift
      • Mar 2011
      • 2459
      I'd say it's the black drum unit - you can't really test single colors totally discrete because the black drum unit is always active, even in single color mode since the print engine can't lift up the transfer belt of the black drum. You can also try to clean the charge roller (a usual suspect) if the drum unit isn't close to the PM yield or older than ~2 years.
      • OutlawTorn
        • Aug 2008
        • 189
        Black drum is at 169k and the ITB cleaning unit has done 240k!
        I was unaware that the black drum is always in contact with the ITB so I guess it is that then - I have ordered the unit so fingers crossed. Will switch out the ITB cleaning unit as well seeing as it is at its life.
        • Eric1968
          • 2458
          169k for a black drum is quiet a lot. Replacing black drum and ITB-Cleaning Unit will solve it.
          If you want to test all colors, you can always print a test page in Printer SP. This will give you a good indication about the drum/dv-units.
          • OutlawTorn
            • Aug 2008
            • 189
            What SP is that Eric?
            I was a bit annoyed that you cant do single colours as I am used to working with Konica Minolta's its a good way to isolate errors like this.
            • TonerMunkeh
              Professional Moron
              • 3865
              You can do single colour copies. There's an SP mode in 5xxx called Colour Mode Selection Display. That enables single colour.
              Hit it.
              • OutlawTorn
                • Aug 2008
                • 189
                Awesome - I was hunting through those SP's but didnt see that one! If the black drum doesnt disengange from the ITB then surely the single colour modes will still have the lines on them anyway?! (if it is the black drum of course)
                • Eric1968
                  • 2458
                  Test patterns are found in SP2-109 (Copy SP). You can also make a test print in Printer SP (don't know the exact SP-number).
                  • teebee1234
                    • Jul 2008
                    • 1670
                    I agree, the printer test page is an excellent tool to gauge each color unit independently for problems. You can easily tell if there is blockage in a particular dev unit or a dirty laser glass. This can be found in Printer SP1 and select Test Page (not sure of exact number, but you will see it). Select Color Test Page.
                    • Gift
                      • Mar 2011
                      • 2459
                      +1
                      You can test this and report back. I'd guess the black drum will still do lines - same goes for the other color units since the machine is only able to lift the ITB from all 3 color drums. But there's no need for complex testing if the lines are just black (or cyan or magenty or yellow) since it's highy unlikely that a faulty yellow unit does black lines
                      The PM yield for the drum units is 120k.
                      • Counsel
                        • Aug 2011
                        • 529
                        Anymore if have issues with a machine and there are items either at or over their pm time, i do all the pm first, 8 out of 10 times that resolves quality problems.
                        • Polarbear
                          • Feb 2012
                          • 1070
                          Printer mode test page
                          1103
                          [Test Page]
                          Prints the test page to check the color balance before and after the gamma adjustment.
                          1103 1 Color Gray Scale
                          1103 2 Color Pattern <This is the one
                          Press the GREEN button!!
