ricoh mpc 2050.sc553 - sc551
  • tullio
    • Feb 2012
    • 268
    ricohmpc2050, errorsc553.After the reset,20 days,same problem.
    thanks
  • Gift
    • Mar 2011
    • 2459
    Re: ricoh mpc 2050.sc553 - sc551
    I think I had this SC because of a bad fuser lamp. I'm note shure if this machine uses more than one lamp because in case it uses just one, the error would reappear instantly - you just might give it a check. If the lamp(s) are OK, you might have a bad thermistor or connection issues.
    • TonerMunkeh
      Professional Moron
      • 3865
      I had a reocurring 553 that was only cured by replacing the ENTIRE fuser. Even after replacing all the parts such as stats, thermistors, lamps etc.
      Hit it.
      • Eric1968
        • 2458
        Had the same. Changed all the usual parts, but ended up replacing the entire Fusing Unit.
        • Polarbear
          • Feb 2012
          • 1070
          I am seeing a trend here, regarding these fusing units. Looks like the thermal fuses on these are not of the best quality, and I am thinking that they trip prematurely, or may even be faulty when you receive them as "new" parts.
          We once had a batch of 1022 thermistors that were faulty out of "new" stock, so nothing is impossible.
          Machines with multiple fusing lamps will run for some time before a code comes up. We have had this happen out here as well.
          Have you checked the thermal fuses when you fitted the replacements, for continuity?
          Just asking.
          Press the GREEN button!!
          • nobody-here
            • Mar 2008
            • 237
            Just asking.
            We have a bunch of MPC2050 / MPC2051 with Sc551/553 errors coming out randomly. We reset code and in some case we change AW100128 AW100127 Thermistors and / or Fusing Belt. But errors may re-appear after some days or weeks or months.
            Firmwares are updated.
            Never changed whole fusing unit, just because in Ricoh Part List we have not Entire Fuser Unit code to order.
            Never changed Fusing Lamps.
            Never changed PSU or other boards...
            TCO is made by fusing problems than toner consumption
            What else could we try to reduce (or not expand) tech costs and better customer satisfaction? Do you think we have to change Boards or Lamps?
            Thank you for your help!
            Vincenzo
            29 rouge unpair manque.... cous cous....
            • ruben
              The New Guy
              • Oct 2012
              • 1203
              Check that both the heating roller and pressure rollers have not become bent; try rolling them on a flat surface and see if any gaps appear. Visually inspect all lamps, and meter them. If you cannot find a fault with either and you have already replaced the thermistors, then I would recommend try swapping parts with a working fuser, starting with a whole fuser to eliminate the machine itself.
              • sanjeev
                replace the fuser unit. problem solved.
                • Mark Bbb
                  • Jun 2012
                  • 1662
                  Hoi,
                  My question might be off the topic, mpc2051, noise:
                  I have lubricate the roller which the belt is moving about...
                  tried to put all together afterwards, impossible to do!
                  Anyone can give me a good tip?
                  Thanks in advance.
                  Greetings,
                  Mark
                  PS: we don't have the issues with SC fuser codes (Belgium, you know)
                  • ruben
                    The New Guy
                    • Oct 2012
                    • 1203
                    Originally posted by Mark Bbb
                    Hoi,
                    Thanks in advance.
                    Greetings,
                    Mark
                    Replace the fuser sleeve, they cannot be easily taken apart and oiled. Any damage or dents made on the sleeve will ruin it.
                    • Besserwisser
                      • 25
                      Have had this many many times, always a bad pressroller thermostat. Have a nice day folks.
