aficio2035
  • vargue
    • Oct 2011
    • 404
    [Electrical] aficio2035
    i have big issue please help i maintained machine in some village in my country with known that electricity in that territory is not stable by the way machine. it's begin to power on and green lamb ignite then and heard motors sound then it's restarted etc....one more time. i replaced power supply.in second pm i tried to unplugged harness pertained to fuser unit it's working and see trays and every thing shown but when yo copying it's make scan . i began to take off some harness in iob/ board input out put/ board it's working i made 3 or 4 copies and return again make the same issue no avail. some suggestions please.notice customer due to weaknes of electricity previously he depended on electricity towers. then he depended on ground terminal is more stronger than towers. please help.
  • sandmanmac
    • 3983
    Re: aficio2035
    I don't know if there is any solution. I always use a good surge suppressor on my installs, even here, where power is relatively stable, because even a small fluctuation in the power supply can send the machine into all sorts of SC codes, not to mention burning out circuitry.
    • vargue
      • Oct 2011
      • 404
      Re: aficio2035
      no sc revealed
      • nmfaxman
        • 1702
        Re: aficio2035
        Door switches or a pinched wire for 24V.
        Remove the fan in front of the fuser and use it on something else that it helps.
        I very rarely have to replace boards on Ricoh boxes.
        Even a pinched wire didn't take a board out.
        K.I.S.S Keep It Simple Stupid.
        As always............................................ .....
        • ucinn
          • Jun 2009
          • 383
          Re: aficio2035
          Check wires in inverter unit. They run a couple across the metal roller shaft. It eventually rubs through the insulation and starts shorting out to frame. Tape them and pout them in the holders with the other wires.
          • vargue
            • Oct 2011
            • 404
            Re: aficio2035
            thanks to all guies electricity is not stable that is thread i brought machine to my office and it's working good no problem??????????/
            • teebee1234
              • Jul 2008
              • 1670
              Re: aficio2035
              You or the customer will probably have to invest in a Line Conditioner or a Voltage Regulater. The Line Conditioner will probably be a cheaper option but is only useful for momentary surges and drops. A Voltage Regulator can have a battery backup that will maintain a constant voltage for a longer period but is much more expensive, especially for a high current drawing device like a copier.
              Here is a link to a Line Conditioner available at Amazon that is pretty reasonable, just to give you an idea.
