how to update firmware ?
  • stupidkiller
    • Oct 2011
    • 57
    i got the latest firmware,but is in SD card [ aficio 3030 ]
    can someone teach me how to update the firmware through SD card ?
    i know is using sp code 107,but can someone tell me which sub code should i go ?
  • sandmanmac
    • 3980
    Re: how to update firmware ?
    In your first thread, you needed the firmware urgently, and for several different models, and some very kind person has provided it to you, and now you don't know what to do with it?
    Really?
    It took me less time to search, and find the free and complete service manual, for the Aficio 3030 online, than it has to write this response.
    • JustManuals
      • Jan 2006
      • 9838
      If you don't know how to update the firmware, then you shouldn't be doing it. Your name fits you.
      • Gift
        • Mar 2011
        • 2459
        • Eric1968
          • 2458
          X2
          • rsyarcia
            Hair Straightener Tech
            • 711
            Originally posted by Eric1968
            X2
            X3
            Nobody is perfect..
            • xordi69
              • Jun 2010
              • 200
              Originally posted by rsyarcia
              X3
              X4
              • kingpd@businessprints.net
                • 921
                You have to get it on the hard drive. Usually through a cable hooked up to a laptop. Not familiar very much with Ricoh stuff.
                It would be great if the machines could go through the net and ping the manufacturers site for a firmware update. Kind of like how my dvd burner drives are although I have to actually download them...really simple and easy though.
                • rthonpm
                  • Aug 2007
                  • 2849
                  That would be a good idea, but Ricoh has some pretty big government customers. Imagine the shock on a network admin's face when the machine started to accept incoming connections! Mainly firmware is there for very specific conditions and is often reliant on a different module being of a certain level.
                  HP had the ability to do this with some of their models but the entire process had to be redone when it was discovered that with a little certificate spoofing you could install malicious firmware.
                  US-CERT Vulnerability Note VU#717921 - Hewlett-Packard printers and scanner devices allow remote firmware updates
                    • 921
                    very interesting. i did not know that.
                    • Venom
                      Technical/IT Support
                      • Nov 2009
                      • 765
                      Create folder B209 on SD card and put firmware there.5.2 FIRMWARE UPDATE
                      The procedure is the same for all firmware modules.
                      NOTE: If you will change scanner firmware, print 5-990-22 and -23 (SMC reports
                      for scanner settings) before you start this procedure.
                      1. Turn off the main power switch.
                      2. Remove the SD card slot cover (􀀎 x 2).
                      3. Insert the SD card [B]
                      IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
                      • teebee1234
                        • 1670
                        1. Turn off the m.........................
                        The root folder must be called "ROMDATA", inside that folder you will place the firmware. If you have several different models to put put on the SD card then you can create subfolders for each (B209, B132, etc.). Otherwise you can load all of it in the romdata folder.
                        • stupidkiller
                          • Oct 2011
                          • 57
                          omg !! thousand thanks on ur help =')
                          i will give myself a try,thanks alot thanks alot n i appreaciate it =')
                          • copymaker
                            • Mar 2010
                            • 16
                            he's of very rare species.Peoples like Venom are very rare in this universe.The person is really appreciable.Herrmann and Gift are also very kind to juniors.
                            Knowledge flourishes by spreading it.
                            • mikadonovan
                              • May 2008
                              • 2931
                              Dude, you really need to get a manual and follow the procedure outlined in the service tables. You can brick your controller if you don't do it right.
                              NEVER ASSUME ANYTHING
