Gestetner 1802d (Ricoh 1018d) SC542
  • jonbonse
    • Jun 2009
    • 737
    Hi all
    I tried to reset the SC error code in SM but the machine immediately displays 'Error!!!' when pressing 'ok' or '#' for enter.
    I've dismantled the fuser and tested the lamp, thermister and fuse all ok.
    Manual says possible faulty thermistor which I agree however what baffles me is that it wont let me reset the SC code. . . Usually you can reset it, then power off/on copier for it to error out again.
    I suspect I have a defective PSU. . .
    Any suggestions (apart from ugrade or throw out of a window)??
    Thanks all!!!
  • ucinn
    • Jun 2009
    • 383
    Re: Gestetner 1802d (Ricoh 1018d) SC542
    Originally posted by jonbonse
    Hi all
    Thanks all!!!
    • femaster
      • May 2011
      • 1514
      Yeah, I had an issue with not being able to clear a similar code a while back. Not sure why they had used that special key combo on these, but it fooled me at first, until I learned the secret.
      • George J
        • 107
        Have you checked the thermostat and thermofuse?
