Sc-390 on gestentner DSM 620d
  • Llama God
    • Mar 2009
    • 1353
    #16
    Re: Sc-390 on gestentner DSM 620d
    Originally posted by pradeesh001
    only TONER DENSITY SENSOR or CONNECTING JACK
    Is Connecting Jack a spin-off of Free Willy?
    • pradeesh001
      #17
      i'm saying about connecting socket inside the machine
      • jake24482
        • Apr 2011
        • 116
        #18
        no nothing is loose i just put new td sensor and initialize developer again still doing same thing .is ther a way to clear the main board or power supply board or any other idea
        • Llama God
          • Mar 2009
          • 1353
          #19
          Do you have another PCU handy to try to eliminate things?
          • jake24482
            • Apr 2011
            • 116
            #20
            unfortunately no
            • Llama God
              • Mar 2009
              • 1353
              #21
              Now you did put the correct dev in, didn't you? B1219640, I believe.
              • jake24482
                • Apr 2011
                • 116
                #22
                that is the part #b121-9640
                • Llama God
                  • Mar 2009
                  • 1353
                  #23
                  Well, as you didn't have the fault before you started but you did afterwards, I'd go with an original drum, blade and replacing the dev again, just to rule all of that out.
                  I'd like to add that we use compatible drums and blades for these machines too, so I'm not having a pop about that!
                  • jake24482
                    • Apr 2011
                    • 116
                    #24
                    yeah i will try some tomorrow and let you guys know if i get somewhere thanks alot for all the info
                    thanks again
                    • jake24482
                      • Apr 2011
                      • 116
                      #25
                      Alright this is all i did .starting from binging customer call for machine was making noise .i went out and saw the gearing system in dv assembly was bad that was causing the noise and making light copies .we replace all five gear and developer . and then machine start popping the Sc390 code .then we replace TD sensor .it still popping the same code .i took the whole drum assembly to an other machine it is popping the same code there as well .if someone has any info about this issue please share what might be causing this.
                      any information will be appreciated
                      thanks a lot guys
                      • pradeesh001
                        #26
                        Causes of sc-390
                        * lack of developer quantity
                        * if agitators are not rotating properly
                        * td sensor or sensor connector
                        * td sensor connecting jack on machine
                        * mother board
                        but in your case pls check first 3 reasons
                        regards
                        pradeesh
                        • TonerMunkeh
                          Professional Moron
                          • 3865
                          #27
                          It sounds like the PCU's just had it. They do expire after a while.
                          Hit it.
                          • vargue
                            • Oct 2011
                            • 404
                            #28
                            i meet this threat in aficio 1022 the image have back ground very dirty... first i make free run 100 copies i suspect in toner i exhausted all toner until t toner signal appear i realized that vt and vts is 0 and when i make dev initialization sc 390 appeared .then switch machine on. sc 390 will dis appear . then yo will get faint image make required maintenance image will be fine...
                            • rsyarcia
                              Hair Straightener Tech
                              • 711
                              #29
                              we encountered this problem and symptom with the same model. we isolated the problem by replacing the developer, initialized it without the toner cartridge. made a copy until the machine asked for toner.Then we inserted the old duplicate toner. When the toner is already loaded we copied some documents but then Error SC 390 pops. So you have to make sure when you change the developer don't use that old toner replace it with orig. As you have said, you tried the pcu on another machine but the same problem so it means the culprit is inside the dev't unit.This is an issue of developer and toner.
                              Nobody is perfect..
                              • jake24482
                                • Apr 2011
                                • 116
                                #30
                                well i ordered new developer and TD sensor .i will set you know if that will fix it i will fallow instructions .i will let you guys know
                                thanks for your time
