Network Scan in JPEG format
  • Alan Aya
    Dear all,
    Got this request from a customer, he wanted the Network Scan ( Scan to Network Folder) to scan in the JPEG File Format and have tried the Ricoh Aficio 3045 ( which stated in the brochure, that it support PDF, TIFF, JPEG ) but it turned out to be in TIFF format when i view the scanned document on the PC. Is there any setting i need to set before i use the scan to network folder function? Can this B/W machine scan in JPEG file?
  • Oze
    Ricoh Fanboy
    • Jul 2008
    • 1663
    Re: Network Scan in JPEG format
    I'm sure that Paul will be along shortly with helpful info
    • Llama God
      • Mar 2009
      • 1353
      It only scans as a jpeg in colour, as far as I know.
      • rthonpm
        • Aug 2007
        • 2859
        Llama is right: Ricoh's scanning convention will allow you three options:
        PDF (black and white or colour)
        TIFF (black and white)
        JPEG (colour)
        The 3045 only has a monochrome scanner so PDF and TIFF are your only options.
        • teebee1234
          • Jul 2008
          • 1670
          Change the Scan Type setting to Gray Scale and it will come out as a JPEG. B/W is 2 bit (TIFF), Gray Scale is 8 bit (JPEG). Gray scale is considered color for all practical purposes.
          • rthonpm
            • Aug 2007
            • 2859
            Well I've met my goal of learning something new today! Rep points for you...
            • Llama God
              • Mar 2009
              • 1353
              Shows how little I know. What you can't see is how little I care...
