Af 1035 Sc320
  • rthonpm
    • Aug 2007
    • 2859
    Af 1035 Sc320
    This is the first of these I've really seen. I tried re-seating the existing polygon motor and all connectors on he LD unit and the box was up and running long enough for me to get a full SMC and test copy out and for the customer to get a few faxes in. It's nuked again now. Is there anything beyond replacing the mirror motor I should try or is the replacement the best option?
  • hosennet
    • Mar 2007
    • 145
    REPLACEMENT AX06 0141 Polygon Mirror Motor (B003/B006)
    AX06 0180 Polygon Mirror Motor (B004/B007)
      • 23010
      Just replace the mirror motor.
      • rthonpm
        • Aug 2007
        • 2859
        I replaced the motor and the code has disappeared. Thanks for the confirmation.
