Aficio 3235c with add black toner problem
  • kassa
    • 79
    Hello guys I have a 3235C with the black toner cartridge full, but it signals to replace the toner.
    The customer has replaced more than one cartridge, but the car after about 200/300 copies, reports back black toner exhausted.
    A month ago have been replaced all the development units and all the drums.
    It occurs to me that now is time to replace the toner attraction pump and the associated tube.
    I read about the service manual, but I was not clear whether to replace the pump to dismantle the rear of the machine.
    For the pump magenta seems that there are also the rear screws.
    Correct me if I'm wrong, please.
    Thanks in advance.
  • Eric1968
    • 2458
    Re: Aficio 3235c with add black toner problem
    If you want to replace the toner pumps, just above the dv-units, you have to dismantle the rear of the machine. Good luck.
    • kassa
      • 79
      Great news
      Thanks for the information.
      • Eric1968
        • 2458
        I guess Ricoh didn't expect these pumps to be replaced very often. If you do this a few times, like I did, it's not that hard. Good luck on this one!
        • Gift
          • Mar 2011
          • 2459
          But they learned from their design flaws (at least in this case) - changing toner pumps at most mid range MPC can be done within minutes.
          • Llama God
            • Mar 2009
            • 1353
            Absolutely, the MPc pumps are a doddle compared to these abortions.
            Anyway, yes, replace the pump.
            • kassa
              • 79
              Thanksto all forthe information.
              I will keep youupdated
