Does scan to folder (smb) compatible with window7 home version
+ More Options
Posts
  • Gesttech
    • Oct 2009
    • 123
    Hi
    Does Scan to Folder on Ricoh Sp3410sf, mpc2051 are compatible with windows 7 home version.
    I tried to share folder. when i tried to scan, connection fail/ cannot find path. But on windows xp & 7 professionel its ok i can scan. Its on a personal computer on a workgroup.
    Can someone confirm me please.
    Thanks.
  • rthonpm
    • Aug 2007
    • 2853
    Re: Does scan to folder (smb) compatible with window7 home version
    CIFS is still a part of Windows 7 Home versions. Try to make sure that Windows Live Essentials isn't installed, and also that the security software on the machine is set up to allow communication with the machine.
    Since this is a Home OS, is this a personal machine or used in a business? It could be that the MFPs are part of a domain, in which case the computer won't be able to connect to them as you cannot join a Home version of Windows 7 to a domain.
    • rsyarcia
      Hair Straightener Tech
      • 711
      We're able to scan to folder in windows 7 starter and Home Version.
      Nobody is perfect..
      • Llama God
        • Mar 2009
        • 1353
        Yes, it works.
        Share the folder, preferably in the root C, change the encryption level down to 40 or 56 bit in the advanced network settings, turn off password protect sharing in the same place, get the path right (try using the IP address or input the DNS settings) and make sure that there are no spaces in the share name (I had this problem yesterday for the first time, but on Professional.)
        Also, has it got a firewall on it? Something like Norton or McAfee.
