MPC 4502 PCU ?
  • knobby
    • Oct 2008
    • 75
    MPC 4502 PCU ?
    Just fitted a black pcu into the colour position by swapping the dev and charge roller assembly. No cutting or swapping of wires needed.
    Only problem was the lub. bar in the black pcu wont fit !
    Any suggestions / info welcomed...
    Has anyone run these or the older pcu's without the lub bar ?
    Cheers
  • knobby
    • Oct 2008
    • 75
    Bump?
    Sent from my Nexus One
    • Gift
      • Mar 2011
      • 2459
      Re: MPC 4502 PCU ?
      too much work - what about the pcu's of the previous gen?
      • rufftouch
        Re: MPC 4502 PCU ?
        • rufftouch
          Re: MPC 4502 PCU ?
          • Gift
            • Mar 2011
            • 2459
            Re: MPC 4502 PCU ?
            thanks for sharing your results - interesting option just drilling a whole and keep the pins since it's messy work to remove them
            • rufftouch
              Re: MPC 4502 PCU ?
              Problem is it can't be done on 4502 (drilling unit) as they have placed pin where gears are I think that's why mpc4502 has come to market so fast but they may still be an answer besides pin removal ?
              • Gift
                • Mar 2011
                • 2459
                Re: MPC 4502 PCU ?
                ok - then we have to keep up the messy work
                • crystal58
                  Re: MPC 4502 PCU ?
                  Cheers
                  Does anybody have a part number for the connector in the back of the mpc 2800 that the color pcu's slide into ?
                  • turbojetboy
                    • Aug 2009
                    • 279
                    Re: MPC 4502 PCU ?
                    Oh dear, another drive assy damaged by all this drum fiddling. You have to replace the entire drive assy - and what a fun job it is.
                    • CanadianKiwi
                      • Nov 2012
                      • 12
                      Re: MPC 4502 PCU ?
                      Try using epoxy first! Changing a drive unit is a job to avoid at all costs.
                      • okirob
                        • Feb 2012
                        • 26
                        Re: MPC 4502 PCU ?
                        My assistant manager has designed a tool to remove the pins takes seconds and no mess at all, will see about posting a pic
                        • locodelacolina
                          • Apr 2013
                          • 7
                          Re: MPC 4502 PCU ?
                          Hello,
                          Can you upload a photo to see it?
                          Regards.
                          • mabawser
                            Tech
                            • Sep 2009
                            • 121
                            Re: MPC 4502 PCU ?
                            a pair of heavy duty snips or metal cutters will do the job in seconds. this is what we do.
                            we use the B2242042 drums for all ranges of machines and modify to suit depending on the range of machine. depending on the range depnds on the extend of mod'ing. the worst it removal of the pin,swap a wire and cut the connector and thats it.
                            • Imprestik
                              • Aug 2012
                              • 297
                              Re: MPC 4502 PCU ?
                              Just get a maintenance kit from the new printer versions SPC830dn
