Pleading the cause of the disappearance of property with a double-sided copiessuddenly in a DSc432c
Problem a double-sided copiessuddenly in a DSc432c
Tags: None
Re: Problem a double-sided copiessuddenly in a DSc432c
not problem in duplex connector
Please check how the system settings Thank you very muchComment
What about the HDD as rsyarcia asked? A dead/disconnected HDD will remove duplexing and finishing capabilities. What are the results if you do an Output Check on the Duplexer motors/solenoid (SP5804-120~125)?Comment
“I think you should treat good friends like a fine wine. That’s why I keep mine locked up in the basement.” - Tim HawkinsComment
