Problem a double-sided copiessuddenly in a DSc432c
  • ali h azez
    • Jan 2012
    • 24
    Pleading the cause of the disappearance of property with a double-sided copiessuddenly in a DSc432c
  • rsyarcia
    Hair Straightener Tech
    • 711
    Re: Problem a double-sided copiessuddenly in a DSc432c
    check the HD, system settings,duplex connector..
    Nobody is perfect..
    • ali h azez
      • Jan 2012
      • 24
      not problem in duplex connector
      Please check how the system settings Thank you very much
      • Gift
        • Mar 2011
        • 2455
        A little side note: Using larger/colored fonts doesn't make this more understandable.
        • teebee1234
          • 1670
          What about the HDD as rsyarcia asked? A dead/disconnected HDD will remove duplexing and finishing capabilities. What are the results if you do an Output Check on the Duplexer motors/solenoid (SP5804-120~125)?
          • KenB
            Geek Extraordinaire
            • Dec 2007
            • 3941
            Nor does it increase any sense of urgency.
            • Oze
              Ricoh Fanboy
              • 1663
              YODA?....IS THAT YOU?
              • Llama God
                • Mar 2009
                • 1353
                Somebody stole your copier? Or did somebody just steal the duplex unit?
                Where do we find these people?
