Cant get rid of this magenta line. Happens on the first three pages printed then goes away and all is good. Replaced magenta drum and pcu and itb assly. Its just with the magenta and it happens with the first three in bw and color. Help appreciated
mpc 4500
Re: mpc 4500
Btw this one has 401k bw. 42k color -
Re: mpc 4500
How many Meter now? does it look like a patch... perhaps you need to replace the ITB Cleaning Assy....fix the customer first then fix the machine... its simple and makes life more easy.Comment
Re: mpc 4500
The dev units can cause lines on these machines, although I haven't seen it at anything as low as this kind of volume. However, if you're getting a magenta line on mono prints then I'd go for the transfer or, as an outside guess, the PTR as the transfer belt should be cammed away from the colour PCUs in mono.
Do you have a sample?Comment
Re: mpc 4500
hope you can make this out. i may need to scan it in this is a picture.Attached FilesComment
