lanier ld525c
  • service
    • Aug 2025
    [Misc] lanier ld525c
    machine makes a high pitched ringing sound (kind of like the sound from older television sets) late in the day after running awhile. I've tried a different fuser but the sound remained. Today i was going to run some output checks but the sound went away for now. It starts when the copy process begins and stops a few seconds after the paper exits....any ideas?
  • Llama God
    • Mar 2009
    • 1353
    Re: lanier ld525c
    One of the PCUs, perhaps?
    • service
      Re: lanier ld525c
      I just ran some output checks, and the only one that duplicated the sound was the blk drm test....tried another blk drum but sound still there
      • Jomama46
        • 2900
        Re: lanier ld525c
        There was a bulletin a while back about a high pitched whining noise coming from the ITB cleaning unit. One of the blades was vibrating. Pull it out and reset it to check or just replace the damn thing.
        sigpic
        A+; Network +; PDI+
        • Llama God
          • Mar 2009
          • 1353
          Re: lanier ld525c
          Or run the machine with the cleaning unit out, perhaps?
          • service
            Re: lanier ld525c
            Turns out it was the black PCU causing the squealing noise. tx
            • Gift
              • Mar 2011
              • 2459
              Re: lanier ld525c
              thanks for reporting back - output check can be confusing sice the machines doesn't always enable single-motor tests to avoid damages (e.g. the transfer belt might get driven as well if you try testing the bk drum motor to avoid damaging the surface of the opc/transfer belt).
              • Iowatech
                Not a service manager
                • 3930
                Re: lanier ld525c
                I've seen that when the black PCU gets noisy, if you pull the front PCU cover off you'll see some brown dust (rust) around the charge roller bushing, sort of like when an electromagnetic clutch goes bad. Something to look for, hope that helps in the future.
