scanner mp 161??
  • loverkoko
    • 35
    scanner mp 161??
    i have problem at mp 161pfs i cant find scanner icon when go service mode
    find copy - printer - fax and no icon scanner can help me ??
  • sandmanmac
    • 3981
    Re: scanner mp 161??
    Is the scanner function available when you press the 'scanner' button, and does it work?
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3944
      There are 3 different versions of the MP161:
      MP161 - Copier only
      MP161F - Copier and Fax
      MP161SPF- Copier. Printer, Scanner, and Fax
      You need the MP161SPF to have scanning, or an MP161 with the optional kit to add the capabilities.
      You cannot upgrade the MP161F at all.
      Check out the attached screenshot from the product support guide.
      • loverkoko
        • 35
        THE scanner function not availabe when i preaa the scanner button and not work
        • loverkoko
          • 35
          MP161 - Copier only
          [ATTACH=CONFIG]15718[/ATTACH]
          the model is mp 161spf
          • teebee1234
            • Jul 2008
            • 1670
            Check this (from Knowledge Base) ....
            Disabling the Document Server using System SP 5-967-001 and Printer SP 1-006-001
            System (Copier) SP 5-967-001
            System (Copier) SP 5-967-001=1 toggles the ability to store jobs to the device hard disk. This affects:
            A) Job Types: Sample Print, Locked Print, Hold Print, Stored Print, Store and Print
            B) All functionality relating to the Document Server (e.g. storing a print job to DS, storing a file from DS interface and from Scanner interface, etc.)
            Settings:
            0 (default): Enables the storage of jobs to the device hard disk.
            1: Disables the storage of jobs to the device hard disk (can be partially overridden by Printer SP 1-006-001).
            • sandmanmac
              • 3981
              Settings:
              I think that the info above applies to another model and not the MP161 as there's NO HDD, DOC server, etc.
              It sounds to me like the SD card has been changed, removed or something .
              Remove the small plastic cover (1 screw) on the left side below the Network interface port, and see if the machine has an SD card. It should be in the lower slot, and it should say "printer /scanner" unit on the card.
              • teebee1234
                • Jul 2008
                • 1670
                [QUOTE=sandmanmac;288892]I think that the info above applies to another model and not the MP161 as there's NO HDD, DOC server, etc.
                Remove the small plastic cover (1 screw) on the left side below the Network interface port, and see if the machine has an SD card. It should be in the lower slot, and it should say "printer /scanner" unit on the card.[/QUOTE
                What you're saying makes sense, but I found the info when I specifically filtered it for that model. Not sure why they have it in the database for it. Maybe they just lumped all of the B\W together.
                • Black & White Multifunction
                • Aficio MP 161/F/SPF
                • Aficio MP 171/F/SPF
                • Aficio MP 1500, 1600/L, 2000/L
                • Aficio MP 2500
                • Aficio MP 2510, 3010
                • Aficio MP 2550/B, 3350/B
                • Aficio MP 2851, 3351
                • Aficio MP 3500, 4500
                • Aficio MP 4000/B, 5000/B
                • Aficio MP 4001, 5001
                • Aficio MP 5500, 6500, 7500
                • Aficio MP 6000, 7000, 8000
                • Aficio MP 6001, 7001, 8001, 9001 (SP)
                • Aficio MP 9000, 1100, 1350
                • Aficio 3035, 3045
                • Aficio 3025, 3030
                • Aficio 2051, 2060, 2075
                • Color Multifunction
                • Aficio MP C6501SP, C7501SP
                • Aficio MP C6000, C7500
                • Aficio MP C4000/G, C5000/G
                • Aficio MP C3500, C4500
                • sandmanmac
                  • 3981
                  [QUOTE=teebee1234;288904]
                  • Aficio MP 2500
                  • Aficio 3035, 3045
                  • Aficio 3025, 3030
                  They must have because i just tried to access SP5-967 on my office machine (MP161), and it doesn't exist
                  • Jomama46
                    • 2900
                    NOt listed in the manual either. 161,171,201. They musta outsourced that answer out to China.
                    sigpic
                    A+; Network +; PDI+
