SPC 811dn
  • Doug James
    • Jan 2012
    • 935
    [CQ] SPC 811dn
    Toner does not seem to be getting to Drum/Dev unit (yellow). Is their a common reason for this problem. Figured I'd better check it out before I go tearing into this.
  • sandmanmac
    • 3964
    Re: SPC 811dn
    Yes.
    Lots of posts about this issue in the copier version of this printer, which is the Aficio MP C3500/4500
    The problem is generally either a plugged toner hose (often due to the use of non-Oem toner) or a shot toner pump.
    • Doug James
      • Jan 2012
      • 935
      Re: SPC 811dn
      Big help, Thankyou so much...
      • JustManuals
        • Jan 2006
        • 9838
        Re: SPC 811dn
        http://www.justmanuals.com
        Paul@justmanuals.com
        • teebee1234
          • Jul 2008
          • 1670
          Re: SPC 811dn
          Ditto on the pumps, that is probably the number one cause of this issue. But you can't rule out the hoses either. The Bk and Y pumps are identical as are the C and M ones, the difference being the angle of the hose nipple. The reason for individual part numbers is because they come with the hoses, which are different lengths and bends for each.
          B2233211 Pump Unit - BK
          B2233204 Pump Unit - M
          B2233203 Pump Unit - C
          B2233202 Pump Unit - Y
