Ricoh 2032 - (was working fine) -replaced toner - now all smudges across paper?
  • jamesrisk
    • Aug 2025
    Hi
    I dont know what has happened
    Was printing fine, toner ran out, replaced, but now the leading edge of the reverse of the first page has a smudge down it, and ALL pages have blotches / smudges on them?
    I have changed the toner again, cleaned the glass, cleaned the roller, and ran through 50 all black sheets, still no joy
    I just dont know whats up
    PCU is only 30,000 sheets old too so dont think its suddenly that as it was fine yesterday!
    Any ideas? thanks
  • xordi69
    • Jun 2010
    • 200
    Re: Ricoh 2032 - (was working fine) -replaced toner - now all smudges across paper?
    Original toner?
    • jamesrisk
      sadly no, but is an orginial PCU
      Just odd it was fine before replacing toner (which wasnt genuine either)
      • xordi69
        • Jun 2010
        • 200
        the best you can do is put the original toner
        • jamesrisk
          yes i know now, but will i need to replace the PCU as well? or will it right itself with the new toner?
          thanks
          • TonerMunkeh
            Professional Moron
            • 3865
            Depends how much toner has gone into it. Fit an OEM toner and run about 500 through it, it the copies clear up, so much the better. This is the problem with non-original toner, you have no guarantee it will be totally compatible. Use OEM where possible.
            Hit it.
            • jamesrisk
              ok will do from now on
              thank you for your replies
              • TonerMunkeh
                Professional Moron
                • 3865
                Thinking about it actually, could you claim the cost of a new PCU from the non-original toner manufacturer? Do they guarantee it to be 100% compatible?
                Hit it.
                • jamesrisk
                  hmm dont know, it was an Ebay job lot of 6, so dont think so (was over a year ago too)
                  • Gift
                    • Mar 2011
                    • 2459
                    - remove the hopper
                    - do as many skyshots until the machine asks for toner
                    - vac out the hopper PROPERLY
                    - install it together with a genuine toner back in the machine
                    - perform another testrund (like printing all SMC lists at least 10 times)
                    Depending on the results you might have been able to recover the PCU - if not, you should replace it. Bad toner can also harm the fuser rollers - better check if the surfaces looks healthy.
                    • tinfox
                      • 317
                      Do you mean smudging as in streaks? Is it on the back as well?
