Ricoh MPC 3500 and windows 7 wont print color pictures
  • Rick
    • Mar 2007
    • 277
    I can print emails and letters in text but as soon as I select a color picture it takes a long time and when it prints it only prints about 1 inch on the edge in black .
    I removed all the printers and reinstalled the printer driver for this and no different . It also display printer error ans says there is a print in que that is holding it up . I perform the detect and repair problem and it says its fixed but It keeps on doing this . Are we dealing with a viris or what ?
  • rsyarcia
    Hair Straightener Tech
    • 711
    Re: Ricoh MPC 3500 and windows 7 wont print color pictures
    in the printer features of the machine check the memory usage..font or frame priority
    Nobody is perfect..
    • sakura
      • 132
      It doesn't sound like a virus.
      Check out this:
      1. Make sure all of the drivers installed on your stations are correct. Also make sure if you are using a printer servers that driver is compatible with your servers OS.
      2. Check out your firmware on a copier - firmware can cause issues while printing.
      3. Check setting on a copier (as mentioned before)
      Good luck
      • Llama God
        • Mar 2009
        • 1353
        What sort of file is it? And what program are you using to open it?
        • Llama God
          • Mar 2009
          • 1353
          Oh, and which driver are you using?
          • Rick
            • Mar 2007
            • 277
            We are using the pcl 5 driver and we are printing JPeg files and memory usage is frame .
            • patterson70
              • May 2010
              • 601
              Corrupted driver? You could try deleting and re-installing the driver.
              • rsyarcia
                • 711
                try to use font if still the same then update the firmware.
                Nobody is perfect..
                • rthonpm
                  • Aug 2007
                  • 2859
                  Just to be on the safe side, have you gone back to the Ricoh website and downloaded the latest version of the driver? Have you also confirmed that it's the MP C3500 driver and not the MP 3500 driver?
                  Seem like obvious things, but some times the simplest things are the easiest to overlook.
                  Also try setting the port for LPR, queue name lp.
                  • Rick
                    • Mar 2007
                    • 277
                    Yup it was a corrupt driver. Thanks guys.
