Ricoh MP171
  • bobthecopierman
    • Mar 2010
    • 53
    Ricoh MP171
    Has anyone seen this? On the back side of a single sided copy, the leading edge has about a 2 inch
    gray band. Only happens on the first copy. The rest are clean. Any tips are appreciated.
  • Gift
    • Mar 2011
    • 2459
    Re: Ricoh MP171
    It's probably an issue with the PCU - the fransfer roller has permanent contact so if there's a slight background on the drum (not neccessarily visible on the prints) it makes the transfer roller dirty until a sheet runs through and removes the toner witht the first rotation. Depending on the copy count I'd consider replacing both PCU and transfer roller.
    • bobthecopierman
      • Mar 2010
      • 53
      Re: Ricoh MP171
      Thanks Gift. Transfer roller did the trick.
      • PinevskiS
        • Jul 2009
        • 283
        Re: Ricoh MP171
        Change PCD UNIT and after that chane transfer roller.
        • kyoceran
          • 100
          Re: Ricoh MP171
          set transfer cleaning from a negative figure to a positive figure, by changing the pcu and transfer roller all you will do is repeat the fault a little further down the line, good luck
