Savin 9020 toner issues
  • ciann176
    I bought toner black toner for a Savin C9020 off of a website and tried installing it today but the copier says there is no toner. I tried shaking it before putting it back in the machine and then rebooted it but the copier still says no toner. What am I doing wrong? Has anyone had this problem before?
  • mikadonovan
    • May 2008
    • 2931
    Re: Savin 9020 toner issues
    Sorry, I had advice for a 9020, which is an old analog machine. After reading your post again, I noticed you said a c9020 which I have not had any experience with.(A lot of typing for nothing after the edit).
    NEVER ASSUME ANYTHING
    • TonerMunkeh
      Professional Moron
      • 3865
      What is a C9020? Can't find anything about it.
      Hit it.
      • Ollie1981
        Toner Monkey
        • Mar 2008
        • 418
        At a guess a Savin branded MPC2000......
        ....which would strongly suggest a toner pump issue. Well that is if the toner bottle the OP bought off "a website" isn't a complete piece of crap.
        • teebee1234
          • Jul 2008
          • 1670
          MPC2030/2050/2550
          • sandmanmac
            • 3979
            Savin C9020 crosses to Ricoh Aficio MP C2050
            What the user is doing wrong is trying to save a few dollars buying sub-standard generic toner which is one of the biggest no-no's there is in these machines. The end-user needs to go back to the supplier, and return the toner, (but I doubt that's possible, so that money's gone too), buy an original cartridge, and hope that solves the problem, and that the toner pump /tubes haven't been clogged up. Trying to save a few buck this way, will cost you hundreds and hundreds of dollars more in repairs, extra replacement toners, etc. etc.
            • exit148
              • Oct 2009
              • 44
              There should be a Chip on that toner ctg. If it is not on the compatible one you bought, the machine will not recognize that a new ctg (with new chip) was installed in it. Therefore making your new toner useless.
