hi i have been working on a richo 350e and i am getting the error code sc 725-00. any help would be great. thanks
richo afficio 350e error
Generally bad power supply, or bad wall power. Test power if you can (at least move it to another power circuit), or try another PS.
Have even seen bad wall power (frequency issues) take out a power supply (twice in a week on same machine). Had to have cust purchase
high dollar power scrubber to straighten out power before supplying it
to the copier.
RegardsComment
to the copier.
Regards
try checking fuses on the power supply board. try turning on the machine without the finisher connected to it because you had an SC related to the finisher maybe the problems on the finisher damaged the power supply, its worth a try 5 minutes.sigpicWe can all Win, but at the end we all loose. Save the greyhoundComment
