Re: mp9001 backgrounding
Hello, I found an issue but not sure if I fixed the problem. I look at the bias adjustments specifically dev. bias image area, initial set at 550 was set at 800 set back 550 no more background. when I did a developer change I cleaned the charge assembly and the potential sensor on the drum assembly. not sure if this problem will return but is there anything else I should consider before closing this issue? I also cycled the machine and I saw the Dev. bias image area change to 554, nothing drastic. Thanks again for all your input
