Ricoh Aficio 1018 (copier/printer)
  • chukfulop
    • Aug 2025
    [Misc] Ricoh Aficio 1018 (copier/printer)
    We have a machine that randomly prints out "Status/Network" Configuration sheets. The sheet has all of the TCP IP information, and information about the machine.
    1) it puts out the sheets and we can't make it stop, what menu controls this?
    2) We cannot access the machine through the network after a day of hard labor?
    19
    Better than the Rest
    0%
    4
    Kills the competition
    0%
    2
    On Par with the leading manufacturers
    0%
    9
    Slightly trailing in some catagories
    0%
    1
    Works Well but wouldn't be my first choice
    0%
    0
    Much to be desired, but it will do
    0%
    1
    A pain in the butt,
    0%
    0
    A Royal Pain and a Nightmare with accompanying Daymares
    0%
    0
    Rather go to a concentration camp that mess with Richo
    0%
    0
    Would make a good punishment for prisoners to deal with these machines
    0%
    2
  • Eric1968
    • 2458
    Re: Ricoh Aficio 1018 (copier/printer)
    Switch off the Auto-Off function in User Tools. The machine switches itself off after some time (default=30 min). When you switch it on, it will print the network page.
    • kyrenecopy
      • Apr 2012
      • 205
      1. Are you able to ping the machine?
      2. How are you connected to the machine?
      3. What program are you using to print to the machine?
      4. Can you do a test print from the driver?
      5. do you have the latest drivers installed?
      6. Are you printing to a LPR port or RAW?
      Testing 1-2-3, testing, testing. Is this thing on?
      • sandmanmac
        • 3985
        I believe on this older box you could log into the 'setup page' of the WIM with username: sysadmin , password: leave blank, or "password" (???).
        Then there was an option something like "print config page at startup" that you could un-check
        • chukfulop
          Originally posted by kyrenecopy
          1. Are you able to ping the machine? No
          2. How are you connected to the machine? through a netgear switch/router (the network card led light on back of the machine turns green when plugged in)
          3. What program are you using to print to the machine? downloaded thelatest driver, attempted to install/find the machine on the network and it wouldn't showup on the network.
          4. Can you do a test print from the driver? No; can't install the printer to do so
          5. do you have the latest drivers installed? Yes
          RAW
          • chukfulop
            When I initially made the change you recommended... it spit another sheet out....
            But it seems to be working so far. i will let you know if anything changes.
            btw... thanks for the feedback on the poll! :-)
            • chukfulop
              I can't see the printer on the network to even log in to the machine.
              • kyrenecopy
                • Apr 2012
                • 205
                Originally posted by chukfulop
                RAW
                Ok, try this. Using a laptop with the printer drivers installed on it, plug straight into the copier using a crossover cable. Make sure the copier and the laptop are both on the same IP address scheme (not the same IP address though). If you can't connect to the copier there is a problem with the network card in the copier.
                • sandmanmac
                  • 3985
                  OOPS.
                  Dammit! I hate it when people don't read the post thoroughly. Now I hate myself
                  • chukfulop
                    OOPS.
                    NP... at least you take the time to care!
                    • totoro
                      • 568
                      X2 on this
                      Totoro
                      • chukfulop
                        cool that sounds viable..... as soon as we can come up with / or make a crossover cable we will test it out..... Perfection.
                        • chukfulop
                          Originally posted by eric1968
                          switch off the auto-off function in user tools. The machine switches itself off after some time (default=30 min). When you switch it on, it will print the network page.
                          it worked... Thank you kindly!!!!
                          • totoro
                            • 568
                            Most newer laptops can use a regular network cable; they will make the switch internally, so if you have a newer laptop you should be golden.
                            Totoro
                            • Eric1968
                              • 2458
                              You're welcome!
