Ricoh MP7500
  • luig
    • Sep 2007
    • 52
    [Electrical] Ricoh MP7500
    I have an MP7500 that turns off when the fuser motor is turned on. I replaced the motor, same thing. when I disconnect the motor and run a copy the machine stays on, but a jam occurs, since the fuser isn't turning. Any good ideas are welcome. Thanks in advance.
  • kyrenecopy
    • Apr 2012
    • 205
    Re: Ricoh MP7500
    Sounds like you have a short somewhere in the fuser assy. Check all you 110v lines and thermistors/24v lines, one of your thermistors may have worn through.
    Testing 1-2-3, testing, testing. Is this thing on?
    • Ollie1981
      Toner Monkey
      • Mar 2008
      • 418
      Re: Ricoh MP7500
      Check no harnesses are shorting to the frame, especially around the fuser drive area and the fuser itself.
      Had one of these the other day that kept tripping out the customer's RCD but without blowing either the 13A in the plug or the various fuses on the PSU. The cause was..... the halfwit who changed the hot roller last had mis-routed the lamp wire causing it to short onto the frame.
      • Eric1968
        • 2458
        Re: Ricoh MP7500
        If there's a short somewhere in the Fusing Unit you'll get SC's. The Fusing Unit is being driven by the CNB-Board. You replaced the Fusing Motor, so that leaves the CNB-board as the only suspect. I assume that the Power Supply can be ruled out because the 24V is present (The machine won't do anything without 24V).
        • Llama God
          • Mar 2009
          • 1353
          Re: Ricoh MP7500
          When you say that turns off, what do you mean?
