wide format fw740 analog
Re: wide format fw740 analog
Hello,
Sorry I haven't gotten back to you guy's about the resolution to the toner problem. I spoke to my boss the following week about the toner issue and he said he had sent two other customers the same toner and there both getting back grounding issues. I'm just waiting for some OEM toner before going back, I'll respond back as soon as the problem is resolved. ThanksComment
Hey I know it's been awhile, the problem was the toner, did a developer change and new toner and all is well!
I have a new problem the I would like to inquire about. This time I'm working on a K+E 5800 you know the one with an easy bake oven for a fuser. (no rollers)
It definitely has a cleaning blade issue but the thing is how do you remove the cleaning blade? I took the top cover off exposing led assy and developer and I see the drum with lines running through it. the copy has just lines no corona arcing so I just wanted to replace the drum blade. I lift up the top cover of the fuser and there is a plate that is spring loaded that is on the back of the process section I'm guessing it's behind their! Any help or literature would be greatly appreciated. Thanks
The customer does not want to spend a lot of money, so were just going for the minimum.Comment
