I know it's old, but only has 50,000 copies on it. The fuser thermistor was blown so we replaced it. We get error E54 which is adjust the setting on the main board. It won't adjust. How many ohms should this thermistor read when disconnected. It reads 11 meg ohm which I think is too much.
The copier won't start until this voltage is correct I presume. Any ideas
