massage appeared on screen functional problem please restart can any one help what' causes this message
aficio 2035
Re: aficio 2035
Enter SP modes and look at the SC code that's causing the restart, that'll tell you what's causing it.It's 106 miles to Chicago. We've got a full tank of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses.
Hit it. -
Re: aficio 2035
Paul@justmanuals.comComment
Re: aficio 2035
For example SC350 is likely a bad toner hopper, SC53x 54x and 55x are all fuser related, and 7xx would be the finisher or other accessories.73 DE W5SSJComment
Re: aficio 2035
322 C 1st laser synchronization error
The 1st laser synchronization signal
cannot be detected by the main scan
synchronization detector board even
if the laser diodes are activated.
Poor I/F harness connection between
the laser synchronization detector
board and the LD unit.
Laser synchronization detector board
out of position and angle of reflection
not correct
defective
LD unit defective
2nd laser synchronization error
The 2nd laser synchronization signal
synchronization detector board even if
Poor connection between the laser
synchronization detector board and
the LD unit.
out of position
defective
LD unit defective
Have you run....
LD Power Adjustment Adjusts the intensity of the laser for the copier,
printer, and fax unit. The Copier and Printer/Fax
settings can be adjusted separately.
2103
5* LD1 Adjustment Start/End
2103*
6* LD2 Adjustment Start/End
(50 ~ 35 / 45 /1 LSB stepWhy do they call it common sense?
If it were common, wouldn't everyone have it?Comment
