scan to folder setup
  • jtymabel
    • Aug 2008
    • 164
    need to set up scan to folder on a mp 7500. the customer wants to scan directly to users workstations, but their passwords change every 2 weeks. is there any way i can set up the paths on the address book, save them with the users names and have the mp 7500 ask for credentials when they are ready to scan to the folders.
    ie.
    scanner----user name----please enter login informantion: user name, password.-----send.
    • 23010
    Re: scan to folder setup
    How about something simpler like having IT set up an admin login/password that does not need to be updated. That's the solution I usually look for in this situation. =^..^=
    • Jomama46
      • 2900
      exactly, its just a checked box to prevent the change requirement
      sigpic
      A+; Network +; PDI+
      • jtymabel
        • Aug 2008
        • 164
        correct, i told them to set up a service account (password will not change)for the copier. To be honest with you guys...they are even contemplating the idea of software for scanning..(a step backwards if you ask me). I have tried to persuade the it dept to do this, but "they have security concerns.".
        i have another question, if i set up PIN for users to access scan to folder, can i restrict that user to only be able to scan to his desktop.? or once the user has access to the scan function can the user access another scan to folder path other than his.
        • sandmanmac
          • 3990
          To the best of my knowledge, 'authentication' can only be set for access to a particular 'function' (Ie: scanner), and not the locations within that function. I'm interested to know why that would be of concern to them, or are they just 'that type of customer'?
          • jtymabel
            • Aug 2008
            • 164
            that type of customer...actually, i think is the head of IT thats being a pain....(its becoming a pissing contest.) I have to babysit them because i just landed the account and im replacing 13 panasonic copiers with ricohs
            • KenB
              Geek Extraordinaire
              • Dec 2007
              • 3944
              Sounds like a GlobalScan or eCopy candidate to me!
              • jtymabel
                • Aug 2008
                • 164
                is globalscan purchased thru ricoh?
                • KenB
                  Geek Extraordinaire
                  • Dec 2007
                  • 3944
                  It's a Ricoh exclusive.
                  You can also get eCopy through Ricoh, as eCopy (Nuance) is a full partner.
                  • teebee1234
                    • Jul 2008
                    • 1670
                    You can enable "Protection Code" in place of or in conjunction with user codes. Each user is assigned an individual code that is required to enable the ability to scan to their individual folder. This is separate from the user code (but can be the same code) needed to access a particular function (ie, Scanner, Fax, Copy,..).
                    I'm also not sure why they would have a security concern regarding setting up a unique user authentication for the scan folder. They can limit it to be able to only have rights to that folder and nothing else.
                    • rthonpm
                      • Aug 2007
                      • 2860
                      Turn on AD authentication?
                      • jtymabel
                        • Aug 2008
                        • 164
                        Protection Code in conjunction with the user codes would be great. How do i go about turning on this feature.
                        • jtymabel
                          • Aug 2008
                          • 164
                          found it...i will try it
                          This section describes how to register a Protection code to a single user.
                          1. Press the [User Tools/Counter] key.
                          2. Press [System Settings].
                          3. Press [Administrator Tools].
                          4. Press [Address Book Management].
                          5. Check that [Program / Change] is selected.
                          6. Select the name whose protection code you want to register.
                            You can search by the registered name, fax number, folder name, e-mail address, or IP-Fax destination.
                          7. Press [Protection].
                          8. Press [Destination] or [Sender] under "Use Name as".
                            Both [Destination] and [Sender] can be selected at the same time.
                          9. Press [Change] under "Protection Code".
                          10. Enter a protection code using the number keys, and then press the [] key.
                          11. Press [OK].
                          12. Press [Exit].
                          13. Press the [User Tools/Counter] key.
