SC-551 on Nashuatec MP C2550
  • certifiedxeroxtech
    • Nov 2009
    • 27
    [Error Code] SC-551 on Nashuatec MP C2550
    Please share the best solutions as the error keeps coming back.
    "prepare your contingency plan as always"
  • rsyarcia
    Hair Straightener Tech
    • 711
    Re: SC-551 on Nashuatec MP C2550
    if it's intermittent better change the themistors. make sure that the machine is connected to a power source that has no fluctuation.
    Nobody is perfect..
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • kyrenecopy
        • Apr 2012
        • 205
        Replace all thermistors, replace thermostats, clean male and female fuser plugs and reseat numerous times, make sure fuser roller is not bad and causing premature toner buildup on thermistors. Make sure you have a dedicated line for the machine and no serious power problems.
        Testing 1-2-3, testing, testing. Is this thing on?
        • Gift
          • Mar 2011
          • 2458
          • sharpmind
            • Sep 2009
            • 478
            I agree with Mr. Yarcia's comment. I would suggest to connect the machine to a voltage regulator to regulate the power supply. If your machine is connected to an extension cord, and several devices are sharing with it, most probably you will encounter fusing error because the CURRENT required by the machine has not been reached.
              • Nov 2009
              • 27
              so far, the best possible way i did is plug the unit to AVR...Thanks folks
              of course i replaced all the thermistors and thermostat twice in a month...
