Help on how to clear SC 542 code on Lanier LD015SPF
  • KJEpps
    • Jun 2012
    • 63
    [Error Code] Help on how to clear SC 542 code on Lanier LD015SPF
    I admit it. I'm a printer tech. The only reason I was working on this machine was because my customer (with all the HP's) asked me to. Since I work on all kinds of units, not just HP, I was willing to give it a try. Their original problem was that it wasn't always fusing the toner. I found a used fusing unit online and purchased it. I didn't ohm it out before installing and it came up with the SC542 error, which I believe is a fuser open heat error. (Correct me if I'm wrong.) So I ohmed out the fuser and found that it was defective. So I put the old fuser back in and still got the error. Is there a key sequence I can go through to clear the error. I'm in a hot spot right now because the unit is completely down now. Help!
    TIA
    KJ
  • sandmanmac
    • 3981
    Re: Help on how to clear SC 542 code on Lanier LD015SPF
    TIA
    KJ
    FYI Machine Xrefs to the more common Ricoh Aficio 1515mf
    Enter SP mode (service mode), then power off/on
    clear modes,1,0,7, (Hold) clear/stop (about 3 seconds)
    • Gary Bowen
      Bowdog
      • Mar 2008
      • 250
      Press the following keys in sequence "CLEAR MODES", "1", "0", "7". Press and hold the "CLEAR/STOP" key until the copier enters the Service Mode (aprrox 3 seconds). Select 1 on the Keypad. Press key "7" and press "OK". Press "807" and "OK" Press the key below "EXECUTE" in the display. Turn Power OFF. Wait a few seconds and turn the copier back ON
      • sandmanmac
        • 3981
        Sorry, "7-807" resets the jam/sc counters, not the actual Error. However, I recalled that that on top of entering' copy SP' mode he will have to enter "5" (OK), "810" (ok), "execute" to reset. The newer models it's just Sp mode and exit
        • teebee1234
          • 1670
          Sandmanmac, you were right the first time on the reset for the LD015/AF1515 but the older Lanier 5613/af1013 used a unique reset.
          B129/B130/B168/B169
          Activate the SP mode, and
          turn the main power switch off
          and on.
          B044/B045/B046
          • JustManuals
            • Jan 2006
            • 9838
            Paul@justmanuals.com
            • KJEpps
              • Jun 2012
              • 63
              Thanks to all, I was able to clear the error and get the unit back up and running.
              KJ
