mpc3500 win 7 pro smb scanning wireless?
  • digicor
    • Jul 2008
    • 1151
    I have mastered win 7 pro smb , no prob, got the fix and all is well, but, i have to have the client hard wire his or her lap top when they are in the office, it will not connect using the wireless access.
    does anybody have a fix or something in the wireless rtr that needs to be config? like firewall? but i can see the wrk grp, but not connect i get the "cant find path,check settings" msg..
    Im thinking there is a wireless 128 enkrypt? or something that has to be configd?in the wireless rtr?
    or is it at the laptop in the wireless prpties? cant find anything that points to a problem..
    any help would be great
    Thank you
  • sandmanmac
    • 3964
    Re: mpc3500 win 7 pro smb scanning wireless?
    Should make no difference at all.
    Only thing I can suggest is if there are other wireless networks/routers within the office/ range of the laptop, that it is connecting to rather, than the proper router that the copier is attached to. It's happened to me on a couple of occasions.
    I would suggest that they probably have different routers for the hard wires (or wall jacks) and wireless, and they are in conflict
    As an after-thought.... When wirelessly connected, can you print and/or ping the machine. If not then, then that's definitely the issue. If you can, then I'm out of ideas
    • ptrflrs
      Glorified Parts Swapper
      • Dec 2010
      • 192
      agree w/sandmanmac ping command is your friend, they r probably on a different wired/wireless network. is it an air/cellular card they r getting on wireless with? must be a local network. also if they r plugged into a cheesy switch try power cycling it, i have had instances where i can ping but no print/scans.
      jesus loves you! (everyone else thinks you're an assh*le)
      street cred: CompTIA A+ & Network+ Certified; Konica Minolta Gold Seal x2,
      Konica Minolta Outward ASSociate, Ricoh, Sharp, Lexmark trained
      • advcopy
        • Jun 2012
        • 25
        good advice will
        Both above reply are soild you may also try looking to see if the router is port blocking it
        • techsass
          • Dec 2010
          • 248
          I'll bet you've already tried, but just in case - try using the IP addy instead of the computer name.
          I don't even check if using the name will work anymore. I guess I should because I'm always waiting for the IP to change & create another trip. So far, so good.
