Aficio 2238C error code
  • hosennet
    • Mar 2007
    • 145
    Hi
    Aficio 2238c display error code SC1002
    Any ideals
  • Wishbone
    • 100
    Are you sure that code is correct? Most Ricoh SC codes are 3 digits.
    • hosennet
      • Mar 2007
      • 145
      Yes I am sure this error code is correct
      Because the model (Aficio 2238c) have RIP on machine
      【リコー公式サイト】お探しのページは見つかりませんでした。お手数ですがURLをご確認の上、もう一度お試し頂くか、サイト検索機能にてお探しください。
      • Ollie1981
        Toner Monkey
        • Mar 2008
        • 417
        http://www.ricoh.co.jp/pdf/34211404/...Neo_C385it.pdf
        I honestly don't know, a search of my Model-J manuals has drawn a blank.
        I'm guessing that it's a variant of the Model-J that isn't available in Europe.
        Sorry mate.
        • paulg
          • Jun 2007
          • 278
          I have seen four digit codes with regards memory and controller faults.
          never worked on one of these with the sd card slots and i think you would need the actual service manual to deal with a complicated controller fault.
          Worth checking the memory dimms and other dims are seated correctly and the hard disk is ok. But over that sorry i can't help you
          • FRIDGEMAGNET
            • Aug 2007
            • 377
            Not sure if this is any help or not but the fax unit has an error 1001. Cant find a 1002 but sometimes codes come to light that are not in a manual.
            For 1001 they say reset the fax unit.
            • JustManuals
              • Jan 2006
              • 9838
              I believe it is a side to side registration error. I have a very usefull FREE text file up on my site at:
              Manuals 4 You - Free on Ricoh and Lanier error codes.
              Feel free to buy something while you're there. Baby needs a new pair of shoes.
              • rthonpm
                • Aug 2007
                • 2854
                Is the device connected to an @Remote gate or other such system that sends data from the device out to another location? The @Remote system will give four digit error codes when losing connection, though I doubt it would kill the entire device...
                Just a thought
